Napisano (edytowane)
Mikrobrand Waldhoff
Link: https://manufaktur-waldhoff.de/
Pokażę kilka modeli które mam od ponad roku i jestem z nich zadowolony.
Pierwszy z nich to model Pioneer Rose Gold Obsidian z chińskim mikrorotorem HZ5500
  • Case: 316L stainless steel
  • Size: 39mm diameter
  • Thickness: 10.6mm
  • Lug to Lug: 46mm
  • Bezel: 316L stainless steel
  • Crystal: Sapphire with anti-reflective coating
  • Caseback: Sapphire exposition caseback
  • Dial: Metallic formed by hydraulic compression with applied metal index
  • Hands: Diamond cut hands with BGW9 Swiss luminous
  • Movement: HZ5500 automatic movement with micro-rotor
  • Jewels: 33
  • Power reserve: 42 hours
  • Functions: Hour, minutes, small seconds
  • Strap: Italian calf leather strap
  • Strap width: 20mm measured at the lugs
  • Buckle: Solid steel with pin
  • Water resistance: 3 ATM / 30 meters
Kolejny z nich to model Quantum Ti Diamond Silver z chinśkim Tourbillonem, szafirową przezroczystą kopertą wykonany z tytanu grade 5.
  • Case: Swiss Sapphire crystal and Grade 5 Titanium
  • Size: 42mm diameter
  • Dial: Hydraulic formed metallic dial w/circular brush, 2 layer with CNC deck
  • Hands: Diamond cut hands with Swiss BGW9 TriTec luminous
  • Thickness: 11.95mm
  • Lug to Lug: 49.8mm
  • Crystal: Sapphire with Anti Reflective coating
  • Caseback: Sapphire Exposition caseback
  • Movement: Hangzhou 36K1 dual-barrel Co-Axial Tourbillon movement with manual winding, 20 Jewels
  • Frequency: 28,800 bph / 4 Hz
  • Power Reserve: 60 hours
  • Strap: Quick-release spring bar (easily interchangeable) with solid Deployant Buckle
  • Strap width: 22mm measured at the lugs
  • Strap material: Italian calf leather
  • Buckle: Deployant Clasp
  • Water resistance: 3ATM / 30 meters
  • Weight: 80gr with leather strap; 115gr with grade 5 Titanium bracelet
Edytowane przez eagle
A tak prezentuje się mikrorotor w Pioneer Rose Gold Obsidian.
Kolejny model diver The Seawolf Blackwater.
Cytat: This timepiece pays homage to the legendary USS Seawolf SSN-21 nuclear-powered, fast-attack submarine.
  • Size: 43mm diameter
  • Thickness: 13.85mm
  • Dial: Hydraulic pressure formed metallic dial, Geneva stripes
  • Index: applied Real applied metal index
  • Hands: Diamond cut hands with Swiss TriTec luminous
  • Crystal: Sapphire w anti-reflective coating
  • Caseback: Screwdown with embossed 3D art and engraved markings
  • Water resistance: 300m / 1000ft
  • Movement: Miyota 9130 mechanical with automatic winding
  • Special feature: Helium release valve at 2h
  • Functions: Hour, minutes, seconds, date, power reserve indicator
  • Bracelet: Quick-release spring bar (easily interchangeable)
  • Bracelet material: 316L stainless steel with independent solid links
  • Buckle: Safety clasp with extension system
  • Weight: 205 gr
Luma jest intensywna.
The Seawolf Blackwater raz jeszcze.
Model Paragon Pearl Obsidian.
Specyfikacja
  • Size: 43.5mm diameter
  • Dial: Metallic formed by hydraulic compression, Freshwater pearl dial
  • Thickness: 11mm
  • Lug to Lug: 51mm
  • Movement: Caliber 96A0 with manual winding, 17 Jewels
  • Frequency: 21,600 bph
  • Power Reserve: 40 hours
  • Strap material: Genuine calf leather
  • Weight: 83gr
