Gość nimnul
Casio SPF-70T 3SENSOR
Gość nimnul
Witam chciałem zasięgnąc opinii o tym oto czasomierzu"TYTAN Casio Sea Pathfinder SPF-70T 3SENSOR"
Gość feleksc
witaj
w ręku czy na ręku go jeszcze nie miałem,ale z tego co przeczytałem to fajny i troche bajerów ma:
• Titanium Band and Case
• Electro-luminescent backlight
Full auto EL light, afterglow
• Solar powered
• Digital compass
Measuring range: 0° to 359°
Measuring unit: 1°
20 seconds continuous measurement
Bidirectional calibration and northerly calibration function
• Barometer
Display range: 600 to 1,100 hPa/mb (17.70 to 32.45 inHg)
Display unit: 1 hPa/mb (0.05 inHg)
Barometric pressure history graph (Graph of 18 hours of pressure readings at 3-hour intervals, which plots rises or falls in pressure as one of five levels)
*Changeover between hPa and inHg
• Depth Gauge
Measuring range:
Depth: 0 to 30 m (0 to 98 ft.)*; Elapsed time: 2:59'59"
Maximum; Water Temperature: -10 to 60°C (14 to 140°F)
*Note that depths between 0 and 1 meter (0 to 4 feet) are registered as 0.0 m (0 ft.)
Display unit; 0.1 m (1 ft.)
Submerged Time: Measured in 1-second increments
Memory Capacity: 1 log data record (total time submerged, maximum depth, water temperature at maximum depth)
*Changeover between meters (m) and feet (ft.)
• Thermometer
Display range: -10 to 60°C (14 to 140°F)
Display unit: 0.1°C (0.2°F)
*Changeover between Celsius (°C) and Fahrenheit (°F)
• Duplex LC display
• 1/100-second stopwatch
Measuring capacity: 23:59'59.99"
Measuring modes: Elapsed time, split time, 1st-2nd place times
• Countdown timer
Measuring unit: 1/10 second
Countdown range: 24 hours
Countdown start time setting range: 1 minute to 24 hours
(1-minute and 1-hour increments)
Others: Auto repeat, progress beeper
• Daily alarms
5 independent daily alarms
• Hourly time signal
• Battery power indicator
• Power Saving (Turns off the display when the watch is left in the dark)
• Auto-calendar (to year 2039)
• 12/24-hour format
• Regular timekeeping: Hour, minutes, seconds, pm, month, date, day
• Accuracy: ±15 seconds per month
• Approx. battery operating time:
5 months on CTL1616 (Operating period with normal use without exposure to light
after full charge)
24 months on CTL1616 (Operating period when stored in total darkness with the Power Save function ON after full charge)
• Size of case/total weight
60.0 X 51.4 X 16.4 mm / 81.2 g
no i duży chyba jest
8)
O_o O_o Duzy i duzo pocji.. ta wyliczanka powoduje u mnie :shock:
wojtek
Gość feleksc
Producent: Casio
Kolekcja: Sea-Pathfinder
Pasek tytanowy
Szkło sferyczne wypukłe
Wodoszczelność 100 metrów
Illuminator automatyczne podświetlenie, które aktywuje się tylko gdy jest za mało światła słonecznego
Kompas wbudowany sensor pola magnetycznego
Głębokościomierz pomiar głębokości zanurzenia na podstawie ciśnienia w wodzie
Ciśnieniomierz sensor mierzący ciśnienie atmosferyczne
Termometr sensor mierzący temperaturę powietrza
Stoper z dokładnością 1/100 sekundy mierzący do 24 godzin
Alarm pięć alarmów dziennych
Kalendarz automatyczny wskaźnik daty pamiętający o krótszych miesiącach
Tryb wyświetlania godziny godzina może być wyświetlana zarówno w trybie 12 jak i 24 godzinnym
Odporność na niskie temperatury gwarantowane prawidłowe działanie zegarka (poza kompasem) przy temperaturze -10 C
Pierścień antyrewersyjny pozwala na obrót tylko w jednym kierunku
Timer odliczanie z autopowtarzaniem
Duplex LCD podwójny schemat wyświetlania informacji na tarczy
Tough Solar panele słoneczne na tarczy ładujące baterie zegarka. (nie wymaga wymiany baterii)
i cena niebanalna :1300pln
Gość nimnul
No tak to wszystko to wiem tylko zastanawiam się jak on spisuje się w użytkowaniu bo jeszcze mam na oku MTG-930DE
wojtek
Gość feleksc
MTG-930DE na pewno dużo odporniejszy(G-Shock) ,no i kosztuje połowe mniej
8)
Gość feleksc
Zegarek odbiera sygnały radiowe służące do synchronizacji czasu z zegarem atomowym
Automatyczny/ręczny odbiór sygnałów
Wyświetla czas i datę ostaniej synchronizacji
TOUGH SOLAR - bateria słoneczna, nie wymaga wymiany
G-SHOCK-odporność na wstrząsy
Czas światowy (29 stref czasowych)
Time stamp zapamietanie wartości chwilowego czasu
5 alarmów-jeden z funkcją drzemki(snooze)
Sygnał godzinowy
Automatyczny kalendarz
Stoper 1/100 sek
Tryb wyświetlacza 12/24 h
Podświetlenie tarczy z poświatą
Szkiełko mineralne
Stalowa bransoleta
Wodoszczelność do 200 m
Koperta z metalizowanego tworzywa umożliwiającego odbiór fal radiowych ---TO JEST CIEKAWE !!!!
Gość nimnul
Przede wszystkim to do pokazywania czasu a pozatym to i na nurach się przyda ale kompa to ja już mam do nurkowania.
Gość feleksc
jesli tak to nie kombinuj i jakiegoś G bierz
8)
Gość nimnul
ale nie wiesz jakie są opinje na temat tego zegarka??
Gość feleksc
ogólnie G wszyscy sobie chwalą,reszta to kwestia stylistyki
i funkcji które są ci potrzebne.
jak dla mnie wazne jest żeby na deklu było Japan wybite,
w made in China spotkałem się z tandetą.
jesli masz zamiar dac za niego ponad 1000 bierz SUUNTO. Nie koniecznie musi to byc komputer :wink:
heh
wojtek
Gość feleksc
heh
co ty tak to Suunto chwalisz?
miałeś to w ręku?
i jak ?
pisz ripo
8)
Gość feleksc
wielgaśny :!:
łape urywa
:twisted:
Gość nimnul
:lol: ja mam wielką łape to może mi nie urwie a zegarek to tylko casio chce poprzedni miałem 8lat ale koperta już nie wytrzymała
Gość nimnul
kuba21 a mozesz powiedzieć mi jak się sprawuje ten zegarek w użytkowaniu??
Gość kuba21
Nie potrafie odpowiedziec bo nigdy go nie nosilem ....ale nosze sam PRG80 ktory jest bardzo podobny ...ma duzo fajnych bajerow ktore sie przydaja na codzien jak temperatura i cisnienie...w ogole to jest dosc duzy zegarek ale da sie przyzwyczaic :wink: bardzo dobrze zrobiony..
Gość nimnul
kuba21 wielkie dzięki za informacje, jeszcze mam na oku ten model MTG-930DE ale zobacze jak aukcja się potoczy :D
