pepco
czy warto z tą cenę 4000 -6000
Wpadły mi w oko te oto zegarki i mam prośbę o ocenę jakości mechanizmów tych zegarków. Pozdrawiam
1/ Movement
Swiss Automatic, Sellita SW200, 26 jewels
Power reserve of 38 hours
Stop-second
Case
Diameter 41 mm
Thickness 9.8 mm
316L stainless steel
Hexagonal crown with engraved "Fleur-de-Lys" logo
Pressure fitted caseback with "Fleur-de-Lys" logo and embossed Clou de Paris decoration
Water resistant to 50 meters
Dial
White, guilloche-style center
Date display at 3.00
Bracelet
Safari colour calf veal leather strap with navy blue stitching
Folding buckle
2/ Movement
Swiss Quartz Chronograph Movement ETA 251.274
Case
316L Stainless Steel case
Water resistance 50 meters
Sapphire crystal with anti reflection
Dial
Sunray black and blue dial
Date at 4.30
Bracelet
Steel 2-row-strap
3/ Movement
Calibre Royal, Manufacture movement with dual direction automatic winding, 21,600 vibrations/hour (3 Hz), Initial force distribution by a central barrel axis, large balance with compensating screws in solid gold, 220°amplitude in vertical position after 72-hours operation.
Large date and day with no amplitude loss upon activation. Unique system for exceptional reliability and accuracy. Integrated complications.
88-hour power reserve design, dial display with 72-hour guaranteed isochronism. Integrated complications.
Large accurate moon phase at 6 o’clock, integrated complications.
Small seconds at 4 o’clock symmetrical to power reserve.
Movement finish: bridges and main plate circular-grained and snailed, with Côtes de Genève.
Oscillating weight with sunray finish and rhodium plating, gilt "Fleur de Lys" logo.
Case
Diameter : 44mm
Titanium
Brushed finish
Case-back secured by 6 titanium screws
Sapphire crystal and case-back with anti-reflection
Titanium crown with relief « Fleur de Lys » logo
Water resistance : 50 mete
Ja tez nie. W tej cenie można kupić Tag Heuer kwarca czy też za niewiele więcej (6k z hakiem ) TH Aquaracer ze stalowym bezelem również na sellicie sw200.
W jakiej cenie masz możliwość nabycia modelu na manufakturowym werku (model 3)?
No to za 25kPLN można już lekko zaszaleć :).
    • Gość
      Przez Gość
    • Przez Frozenn
      Witam. Zegarek w świetnym stanie, pełen zestaw sklepowy. Żadnych śladów użytkowania, poza naturalnie występującą patyną. Ode mnie forumowe 8,5-9/10. Zegarek świeżej produkcji i zakupu: 02/2025. Noszony na zmianę z innymi, uszanowany i użytkowany zgodnie ze sztuką. Marki Venezianico raczej przedstawiać nie trzeba. Świetny design, materiały, trwałość i sprawdzone mechanizmy. Ten tutaj, to akurat nie lada gratka dla fanów patyny i szwajcarskich automatów :))
      Trochę specyfikacji:
      - 42mm średnicy bez korony
      - 49mm L2L
      - około 13mm grubości
      - koperta, bezel, wkładka, korona z brązu
      - szkło szafirowe, płaskie
      - uszczelnienie 30 atmosfer
      - zakręcana, sygnowana korona
      - mechanizm Sellita SW200-1, automat
      - pięknie szlifowane, nakładane indeksy
      - szlifowany, zdobiony dekiel
      - gumowy, bardzo wygodny pasek
      Krótko o mechanizmie: znana i trwała konstrukcja Sellity, napędza większość zegarków w przedziale cenowym 2,5-9k zł, 26 kamieni, 4 cykle na sekundę czyli 28800 bph, wskazówka płynie miło dla oka. Mechanizm ma świetne osiągi, noszony na codzień spieszy się +1 sekundę na dobę, czasem +2, a czasem pójdzie równo bez odchyłki, uśredniając, robi +1. Świetny rezultat, bez mała jak chronometr Nie noszony, odpoczywa w rotomacie, mechanizm nie ma zastojów.
      W zestawie znajduje się wszystko to, co otrzymujemy w salonie przy zakupie nowego. Począwszy od pudełek, przez komplet dokumentów: karta cyfrowej instrukcji, dowód zakupu, certyfikat, mapa Wenecji, sklepowa zawieszka, wszystko ująłem na zdjęciach. Dodatkowo dorzucam dokupiony, brązowy pasek skórzany, nigdy nie używany. Fabryczna guma jest świetna!
      Obecnie cena nowego w tej konfiguracji waha się w granicach 4800 - 5200 złotych, w zależności od sprzedawcy i jego marży. Kwota jaka mnie interesuje to 3200 3100 2999  REALIZACJA Do niewielkiej negocjacji. Stanowi to około 55% ceny nowego. Koszt paczkomatu po mojej stronie, odbiór własny oczywiście również jest możliwy. Ewentualnie zaproponuj inny sposób dostawy - dogadamy się.
      Zapraszam do galerii poniżej oraz do rozmów.
      Pozdrawiam gorąco,
      Maciej.
      PS. Zdjęcia autentyczne, bez fotoszopowania i innych bajerów.
    • Przez Frozenn
      Pozdrawiam, Maciej.
    • Przez Depipi
      Poszukiwania idealnego czasomierza do noszenia na co dzień dobiegły końca, gdy moje spojrzenie padło na zegarek Ball Fireman Enterprise o numerze referencyjnym NM2098C-S20J-BK. Wystarczyło jedno spojrzenie na wskazówki sekundnika ozdobione historyczną sygnaturą „RR”, bym wiedział, że to ten. Ta delikatna i zarazem mówiąca wiele historia fascynuje mnie bardziej niż cokolwiek innego na rynku - z wyjątkiem oczywiście oferty Longines, której subtelność również mnie zachwyciła.
      Ball i Longines, dwie marki, które od lat uznawane są za kwintesencję elegancji i precyzji w świecie zegarmistrzostwa. Ich niezwykłe dziedzictwo to coś więcej niż tylko pomiar upływu czasu - to opowieść o pasji, innowacji i doskonałości. Dlatego też wybór pomiędzy nimi był dla mnie wyzwaniem. Jednakże, gdy spojrzałem na zegarek Ball Fireman Enterprise, wiedziałem, że to właśnie ten zegarek łączy w sobie wszystko, czego szukałem.
      Teraz, nosząc go na moim nadgarstku, czuję, że mam nie tylko coś pięknego, ale również coś, co ma znaczenie - połączenie historii, tradycji i nowoczesności, które sprawia, że każdy moment staje się wyjątkowy.
      Choć prezentowany model jest podstawowym i najtańszym w ofercie firmy, nie oznacza to wcale niższej jakości wykonania czy stosowania gorszych materiałów. Zegarek Fireman od Ball’a wyróżnia się jakością wykonania i dbałością o detale typowe dla marki. Co więcej, jest to jeden z niewielu modeli oferowanych przez Balla, który jest odbierany jako bardziej elegancki niż sportowy.
      Już na pierwszy rzut oka zwraca uwagę minimalistyczny design tarczy, pozbawiony zbędnych elementów, co sprawia, że odczytanie czasu jest intuicyjne i łatwe w każdych warunkach świetlnych. Obecność trytu oraz wewnętrznej powłoki antyrefleksyjnej zapewnia czytelność przy różnym nasłonecznieniu.
      Producent oferuje dwie wersje kolorystyczne tarczy - czarną i białą. Warto jednak zauważyć, że w obydwu wariantach datownik ma takie samo tło, co może prowadzić do zbyt wysokiego kontrastu w przypadku wyboru zegarka z czarną tarczą.
      Bransoleta ma jednakową szerokość na całej długości, co nadaje charakterystyczny wygląd sportowego modelu z nutą elegancji. Zarówno koperta, jak i bransoleta są wykonane w całości ze stali nierdzewnej klasy 904L. Ta szczególna stal, z dodatkową zawartością miedzi, cechuje się jeszcze wyższą odpornością na korozję, kwasy, wysokie temperatury oraz uszkodzenia mechaniczne, dzięki czemu osiąga jeszcze wyższą twardość w porównaniu do tradycyjnych stali nierdzewnych wykorzystywanych w zegarmistrzostwie.
      Aktualnie tylko dwie marki zegarmistrzowskie, Rolex i Ball, korzystają ze stali 904L. Dlaczego producenci podejmują taką decyzję? Aby osiągnąć jeszcze wyższą jakość. Jeszcze wyższą precyzję wykonania. Chcąc zapewnić zegarkom trwałość na najwyższym poziomie, wybierają stal o jeszcze lepszych właściwościach. Dążąc do doskonałości.
      Warto również zwrócić uwagę na jakość wykonania ogniw bransolety, które posiadają bardzo gładką powłokę pozbawioną ostrych krawędzi. To szczegół, który podkreśla dbałość producenta o detale i użytkowników, zapewniając komfort noszenia nawet podczas codziennego użytkowania.
      Mechanizm automatyczny zastosowany przez Ball Watch Company w modelu NM2098C-S20J-BK nosi oznaczenie RR1103. Zgodnie z dostępnymi informacjami, opiera się on na klasycznym ETA 2824-2 w wersji elabore, wyposażonym w 25 kamieni łożyskowych oraz rezerwę chodu wynoszącą 38 godzin. Warto przypomnieć, że mechanizmy tej klasy są regulowane w trzech pozycjach, a ich dzienne odchyłki nie powinny przekraczać +/- 7 sekund. Pierwsze pomiary własne potwierdzają, że odchyłka dobowego działania wynosi zaledwie trzy sekundy z tendencją do utrzymania tego wyniku nawet przy codziennym noszeniu.
      Bardzo dużym zaskoczeniem okazało się, jak doskonale zegarek leży na nadgarstku. Pomimo średnicy koperty wynoszącej 40 mm i odległości "lug to lug" wynoszącej 48,5 mm, idealnie dopasowuje się do wielu standardowych nadgarstków, stanowiąc solidną konkurencję dla wielu zegarków przeznaczonych do codziennego noszenia. Patrząc na zegarek z boku, widoczne jest, że uszy koperty są najbardziej wysuniętym w dół elementem, co przekłada się na komfort i idealne dopasowanie do nadgarstka.
      Zapięcie bransolety, składające się z trzech elementów, stanowi patent firmy Ball. Jednym z jego zdecydowanych atutów jest harmonijne wpasowanie się w całościowy design zegarka. Chociaż otwieranie zapięcia może wymagać pewnego przyzwyczajenia, warto zauważyć, że mechanizm jest wyposażony w blokadę uniemożliwiającą przypadkowe otwarcie.
      To było moje pierwsze doświadczenie z trytem, i na początku miałem obawy, że pałeczki z systemem Night Reading Evolution z biegiem lat mogą negatywnie wpłynąć na wygląd tarczy i całego zegarka. Okazało się jednak, że była to niewłaściwa obawa. Tryt zamknięty w szklanych tubkach w ciągu dnia prezentuje się jak subtelnie zabarwione indeksy ze szkła, co ostatecznie wpływa korzystnie na cały design. Doceniłem to szczególnie w zimowe poranki, kiedy słońce wstaje o 7:40, a ja muszę być gotowy do wyjścia z domu już o piątej rano.
      Żywotność trytu w zegarkach Ball wynosi przewidziana jest na 25 lat, przy czym połowiczny rozpad następuje po około 12,32 latach. Po upływie tego czasu można wymienić tarczę wraz ze wskazówkami na nowe w ramach serwisu. Na dzień dzisiejszy koszt takiej usługi wynosi 1 860 zł.
      Zegarek dostępny w oficjalnym polskim sklepie to koszt rzędu 6 270 zł.
      W kategorii oferowanej jakości w stosunku do ceny, trudno znaleźć markę lub model, który mógłby konkurować z tym zegarkiem. Osobiście jednak, byłbym skłonny do dopłaty za mechanizm klasy Top lub COSC.
    • Przez Depipi
      Post ten jest moim drugim podejściem w poszukiwaniu drugiego zegarka automatycznego.
      W poprzednim wątku zatytułowanym „automat do noszenia „na co dzień” ” poszukiwałem zegarka japońskiego, mniej formalnego z naciskiem na open heart, wskaźnik położenia księżyca, na skórzanym pasku- budżet wynosił wtedy 6500.
      Szukając, przymierzając, a także czytając zmieniłem preferencje dotyczące poszukiwanego zegarka.
      Interesuje mnie:
      ·        Zegarek „swiss made”
      ·        Napęd mechaniczny z automatycznym naciągiem
      ·        Płaskie, szafirowe szkło z mile widzianym antyrefleksem
      ·        Minimalistyczna, piękna tarcza (dopuszczam wskaźnik dnia miesiąca, rezygnuję z open heart, księżyca i wskaźnika rezerwy chodu)
      ·        Raczej skórzany, czarny pasek jednak ze względu na cel (zegarek do noszenia na co dzień do pracy, do koszuli, coś formalnego ale mniej niż moje dotychczasowe Seiko SARB065) dopuszczam bransoletę
      ·        Średnica koperty maksymalnie 41, idealnie będzie 40. Nadgarstek w obwodzie ma 18,5 cm.
      Zamiast tych wszystkich udziwnień i komplikacji chcę postawić na dobry, sprawdzony i trwały mechanizm.
      W czytanych testach podobają mi się:
      ·        Mechanizmy o wysokiej częstotliwości pracy (28800/h)
      ·        Rezerwa chodu wynosząca powyżej 50 godzin, blisko 70 byłoby idealnie (odkładając zegar z piątku na poniedziałek)
      ·        Zastosowanie krzemowej sprężyny balansu
      ·        Jeżeli będzie to ETA lub pochodna tego mechanizmu to mile widziana w wersji TOP lub COSC
      Marki zegarków, które zrobiły na mnie wrażenie podczas poszukiwań:
      ·        Longines- styl i wzornictwo, które ewidentnie do mnie trafiają
      ·        Ball- jest w nich coś wyjątkowego
      ·        Cuervo Y Sobrinos- wyglądają bardzo niepowtarzalnie
      Mile widziane Wasze zegarkowe propozycje oraz opinie.
      Nie rozumiem jednego. Czytając opinie o Cuervo na hiszpańskich forach oraz na reddit wszyscy piszą, że są za drogie względem mechanizmów, które oferują. Przykładowo ich mechanizm CYS 5124 oparty jest na Joux-Perret G-100, a ten z kolei kompatybilny jest z ETA 2824-2.
      Tylko… czy w przypadku innych producentów zegarków jest inaczej?
      Rzeczywiście bardziej zawyżają ceny względem np. marki Longines?
      Przyznam, że poszukiwania prowadziłem również od drugiej strony- szukając mechanizmów, które mi się podobają, a dopiero następnie zegarków wyposażonych w wybrane mechanizmy.
      Być może to głupie rozumowanie ale średnio patrzę na zegarki o wartości 10 000 zł widząc ten sam mechanizm w zegarku za 2100 zł nawet, jeżeli ten pierwszy jest mocno dopieszczony.
      Mój nieprzekraczalny budżet to 8000 zł ale nie muszę go wykorzystać w całości- równie dobrze mogę kupić zegarek za 3000 zł jeżeli poczuję, że to jest to.
      W załączniku przesyłam kilka zdjęć dla rozbudzenia wyobraźni.
      Jeżeli moje wymagania są zbyt wygórowane w stosunku do założonej kwoty to idę na ustępstwa stawiając na pierwszym miejscu jakość mechanizmu.
